I have tried the window lock switch and it makes no difference.  Last winter I accidently cut a wire that was hanging out of the windshield gasket on the passenger side.  The first time after cutting the wire I tried the pasenger window it did not work.  Wondering if that wire could have something to do with the window lock or if it is a coincidence since the wire is cut now and it doesn't work.  I think the windshield is going to have to come out to fix the wire.  What i realy need to know is what that wire is for.  It appears to run top to bottom on the passenger side under the windshield gasket.
  • 10 months later...
Have you tried the window switch on all the doors or just the master window switch’s on the drivers door
