fastcat800 Posted April 19, 2023 Posted April 19, 2023 I have tried the window lock switch and it makes no difference. Last winter I accidently cut a wire that was hanging out of the windshield gasket on the passenger side. The first time after cutting the wire I tried the pasenger window it did not work. Wondering if that wire could have something to do with the window lock or if it is a coincidence since the wire is cut now and it doesn't work. I think the windshield is going to have to come out to fix the wire. What i realy need to know is what that wire is for. It appears to run top to bottom on the passenger side under the windshield gasket.
HaloRomeo27 Posted February 25 Posted February 25 Have you tried the window switch on all the doors or just the master window switch’s on the drivers door
