MY02 Posted September 22, 2004 Share Posted September 22, 2004 Hi, everybody, I am new to this forum. Just got a 2002 LS430 out of warranty. One of the brake bulb is not working. I can't find the instruction on manual. Can anybody help me on changing these light bulb? Also, I wonder how to change the brake light bulb on the rear window. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Lexls Posted September 23, 2004 Share Posted September 23, 2004 Welcome Changing bulbs is usually pretty easy. Now I don't know much about the 430's but I can give you some guidance.... I can't find a pic of the high mounted stop light but you can check my removing sub cover tutorial http://www.lexls.com/subcover.html it may give you some ideas. If you can post a picture I may be able to help you more. However, if you want to know how to do things on your car I suggest you spend ten bucks and download your repair manual from TIS: http://www.lexls.com/repairmanual.html I hope this info helps you some. Good luck :) Quote Link to comment Share on other sites More sharing options...
Lexls Posted September 23, 2004 Share Posted September 23, 2004 Welcome Changing bulbs is usually pretty easy. Now I don't know much about the 430's but I can give you some guidance.... I can't find a pic of the high mounted stop light but you can check my removing sub cover tutorial http://www.lexls.com/subcover.html it may give you some ideas. If you can post a picture I may be able to help you more. However, if you want to know how to do things on your car I suggest you spend ten bucks and download your repair manual from TIS: http://www.lexls.com/repairmanual.html I hope this info helps you some. :) Quote Link to comment Share on other sites More sharing options...
