dink23 Posted September 22, 2004 Share Posted September 22, 2004 I have been having some issues with my Homelink system. I program button one for my garage and it works fine for weeks and then it won't open my garage door at all and I have to reprogram it. However now I can't get the lights to flash at all. they just stay steady when I try to program the remote. I have even tried resetting the homelink by holding down the 2 outside buttons, but I cannot get them to flash. No matter what I do, the light only stays constant. I have tried holding the buttons down for minutes at a time and the light will not flash. My first question is that does anyone know a workaround and my second question is why does my homelink system continue to forget it's program (when I can get it to program. I am no newbie to the Homelink system. My last car had it and I never had to reprogram it, plus I also have an RX330 and it programs like a charm. I just can't get my IS300's lights to flash. Any advice would be great. Quote Link to comment Share on other sites More sharing options...
steviej Posted September 22, 2004 Share Posted September 22, 2004 here is a thought maybe check the fuse, it may be loose. All you need is a disrupt in the current and it might be losing the homelink memory. Find the fuse and see if that is loose. My homelink is hooked through the DOME fuse (#34). I won't see any disrupt while driving because this fuse controls all the courtesy lights which are off when the car is in motion. steviej Quote Link to comment Share on other sites More sharing options...
