Adjusting Headlights
95LS400Bob
Pulled the front bumper to repaint it and noticed the headlights have little bubble levels on them. Before removing, noticed the drivers side was level but the other side nowhere near.
Somebody with a manual..tell me if you just adjust them both level or what the deal is. Thanks.
There is a screw near the Headlight assembly and the level. Depress or release it and the level should adjust itself.
I would recommend finding a level ground to work on, and a white wall to make sure the focus points aren't over-adjusted. You should also measure the beam height on the leveled one.
