Jean Posted June 22, 2004 Share Posted June 22, 2004 Recently we purchased a 2000 Lexus RX300 and had a trailer hitch installed to pull a pop-up camper. The camper is 1500 lbs not loaded we estimate 2000 lbs loaded and I would stay that is high. We turned off the overdrive to tow per the owners manual. The problem is while towing the car jerks it will stop for a few minutes then do again. Any ideas of why or what we can do to eliminate this problem? Thanks, Jean Quote Link to comment Share on other sites More sharing options...
bluestu Posted June 23, 2004 Share Posted June 23, 2004 I don't think I would try towing anything with an RX300. The car does not have enough power or torque for towing a 2000 lb. trailer. You'll probably ruin the transmission which is very expensive to replace. Quote Link to comment Share on other sites More sharing options...
