Removing rx300 rear knuckle
I need to replace an ABS reluctor (tone) ring, driver side rear.  Can I safely remove the knuckle and hub as a single piece?   Looks like I can disconnect the suspension connections and bang it off from the inside.  Otherwise, getting the hub off first is a pain after over 16 years of being frozen on, and special tools likely are needed.
