aw4golf Posted September 21, 2021 Posted September 21, 2021 (edited) New member- I bought a used 2012 RX450h (with 94,018 miles & now have 97452 miles) and my trusted mechanic said his 'book' said 17 hrs labor to replace bushings due to having to lower the 'sub' frame first then lower the trans and engine to get to the arms to replace the bushings. He showed me that the right front wheel moves when he slowly backed it up and braked. The wheel moved forward (didn't stop with the fender). I go to him because he never up charges on parts that you don't need. This appears to be the first RX450h he has done because he had to check on the labor hours. His labor rate is $110/hr. Anyone know if there is a quicker way he could use to do this repair to reduce all that labor cost? Thanks in advance. Allen Edited September 21, 2021 by aw4golf added more text.
