AFS Sensor Replacement Mishap
So i was going to fix the AFS sensor in my 2011 GS350 and i took off the sensor and the entire sensor assembly seemed fine but the piece connecting it to the suspension snapped. I wanted to take off the other end of the connector so i tried to take out the bold and the bolt snapped on one side. i can’t take it out at the moment because there is some tension on it. i was wondering if anyone knew what the bolt was attached to because it went through a bushing which connected to what i assume is the bar in the back for stability (i forget the name). i’m not sure what it is honestly but i was hoping someone else could inform me and tell me if it’ll be a big problem and if i should drive the car too much or not.
