Guest Posted January 4, 2020 Share Posted January 4, 2020 What should I expect to pay for a new audio door motor? My 2007 SC's audio door does not work. I assume that a Lexus dealership will be very expensive. Any ideas? Is it a DIR repair? Thanks! Quote Link to comment Share on other sites More sharing options...
Bob McMoe Posted July 24, 2020 Share Posted July 24, 2020 On 1/3/2020 at 9:39 PM, Steve Andriole said: What should I expect to pay for a new audio door motor? My 2007 SC's audio door does not work. I assume that a Lexus dealership will be very expensive. Any ideas? Is it a DIR repair? Thanks! I have 07 that I had to replace the audio door on as well. I found a replacement (used audio door and motor) on eBay for a little over $100 if I recall correctly. I replaced the motor and swapped out the door as it was lighter wood then the original and it has worked just fine ever since. good luck! Quote Link to comment Share on other sites More sharing options...
