ryan632 Posted October 12, 2015 Posted October 12, 2015 My sc300 has been having trouble shifting into overdrive. Sometime it will shift just fine, and other times it won't go into overdrive. I just had the capicators in the ECU replaced, and its still doing it. I have also noticed that the spedomoter is off by about 10 MPH, and the tach is off as well. Is it possible that the circuit board is bad. I did a fluid and filter change back in March. The car has 256,000 miles on it. Any advice would be greatly appreciated. Thanks Ryan
Rider3r Posted January 22, 2016 Posted January 22, 2016 I had the same problem when i first got the car. It is a 95 with 114,xxx miles. i have not found a solution yet i just know it gets worse. I have to manually shift it into first if not it is stuck in third no matter how slow of fast your driving. I've had the trans rebuilt and nothing changed. I am ruining out of things to try and fix it.
ryan632 Posted January 22, 2016 Author Posted January 22, 2016 I ended up replacing the ecu with a refurbished one and have not had a problem since.
