Help! Stuck Camshaft Bearing Cap Prevents Me From Replacing Camsha
Magda
This thread is already solved. I just wanted to thank you for your input and post some pics that are associated with the work I did.
80-20150616_ls400_7616_963da830f70f79aca
Halfmoon plugs before cleanup
80-20150622_ls400_7630_f3c21cba63010f512
Cleaned valve covers with new spark plug seals and gasket, halfmoon plugs, rear cam bearing caps and valve cover bolts with new washers.
80-20150622_ls400_7640_d5820ef3b432edbed
Cleaned halfmoon plugs, rear cam bearing caps and valve cover bolts with new washers.
80-20150622_ls400_7645_6abbfab9543e938ca
New sparkplug seals
80-20150622_ls400_7646_72c2870c4bdba8b23
Installation
of new sparkplug seals (I already installed it and bent the metal tab
back... so this is just a demonstration of my technique)
80-20150622_ls400_7647_dce642855e95d247b
Adjusting
new sparkplug seals so that they sit flush. This is also a way to
remove them (just make sure that the metal tabs on the reverse are bent
out of the way)
80-20150623_ls400_7662_c5d79660d133cf570
Rear plug in the background, ready for installation.
