xclsior Posted February 28, 2015 Share Posted February 28, 2015 Hey guys, so i recently swapped my sc300 with a 1jz non vvti. The car is overheating after about 5-10m of sitting at idle. I am not sure what it is. I removed the thermostat to see if that was the issue but it still does it. The water pump is working, as i have circulation in the coolant and my heater does blow hot. Now i let it run a bit with the needle on hot and kept checking the hoses. The hose gets warm, and the water gets warm, but the hose doesnt stiffen up or anything. i can touch the block and head and its warm but it doesnt burn or anything. is there maybe something wrong with the coolant temp sensor? or some wiring difference that i needed to do? Quote Link to comment Share on other sites More sharing options...
paulzy Posted May 22, 2015 Share Posted May 22, 2015 have you grounded your temp sensor yet? Quote Link to comment Share on other sites More sharing options...
