Rich A Posted September 10, 2014 Posted September 10, 2014 Ive tried to remove the assembly, the two plastic nuts were removed but the part will not come out so i can replace the bulb. It can be lifted a bit , but it doesn't come out. Tried using screwdriver to pry it out. I'm assuming there is no need to remove the the whole insulation panel to get at the bulb. It's a 2003 Lexus ES300 with tail light as part of the trunk lid.
