96 Es300 - Problems Starting And Sensor Problem
I've been having some problems starting my '96 ES300. Sometimes when starting it, it wouldn't turn over. The radio and AC would come on, but that was it. If I turn it off and let it sit for a minute, then it'll start. It would work fine while driving and everything worked after it started. I took it to AutoZone for a free check. A guy put a tester on the battery and I could see that it said: "bad battery". The battery is only maybe a couple of years old. He said that the problem is probably that the alternator needs to be replaced. I can take my car back to the shop where I bought the battery since it's still under the 5-yr. warranty to maybe have them replace it (again). Should I also have the alternator replaced?
Also, the check engine light has came on. I don't know if this is related or not. I had AutoZone check that, too, and was told that the problem is: "P0150 - Heated Oxygen Sensor Circuit Malfunction". Is it OK to drive or is it critical that I get this replaced right away? Thanks.
