When we go to a new place, we need our cars, and we also need GPS devices. Car and GPS device are just like a couple, they need each other. But maybe you don't know, we also need GPS jammer. That is because GPS device has become a dangerous thing which could easily expose our locations. Bad people can easily track down someone's location, only by putting a small GPS device in his car. But when we have GPS jammer, it could block GPS signal, thus disable all GPS devices in a certain range to protect us. Below is an outstanding GPS jammer, the 5 High Power Antennas Phone Jammer and GPS Jammer, model number S805014. Do you want to live in a quiet and peaceful environment without the noise of cell phone? And are you puzzled with the problem that sometimes you are tracked by someone that you even don't know. With the 5 High Power Antennas cell phone jammer and GPS Jammer, you can fully enjoy your privacy. It is not only a GPS jammer, but also a mobile phone jammer.
This device can block all kinds of signals including CDMA (870-880MHz), GSM (930-960MHz), DCS (1805-1880MHz), PCS (1930-1990MHz), 3G (2110-2170MHZ), and GPS (1570-1580). The jamming range is up to 40 meters. In the summer, you might be worry about the heat dissipation problem. This jammer builds in the cooling fan inside that has good cooling system. With AC adaptor it can work non-stopped. What's more, it can work in your car with car adaptor. With GPS jamming function, you couldn't be tracked by someone.
The 5 high power antenna phone and GPS jammer can be applied at meeting rooms, conference rooms, museums, theatres, concert halls, churches, temples, classrooms, factories, banks, trains, bus and more. If you want to look for a high quality and cheap jammer, this is your best choice.
Product Notes
The jamming distances we mentioned on website are for customer's reference only. The actual jamming distance will be varied depending on the signal strength and the use location and if full charges, etc
Technical Specification
Cover interface standards:
-CDMA: 870-880MHz 34.5dBm 5dBm/30KHz(min)
-GSM: 930-960MHz 34.5dBm 5dBm/30KHz(min)
-DCS: 1805-1880MHz 33dBm -2dBm/30KHz(min)
-PCS: 1930-1990MHz 33dBm -2dBm/30KHz(min)
-3G: 2110-2170MHZ 33dBm 0dBm/30KHz(min
-GPS: 1570-1580 33dBm 5dBm/30KHz(min)
Total output power: 12W
Jamming range: up to 40m, the jamming radius still depends on the strength signalin given area
External Omni-directional antennas all the TX frequency covered down link only
Power supply: 50 to 60Hz, 100 to 240V AC
With AC adapter (AC100-240V-DC12V),
Dimension: 257 x 140 x 51mm
Full set weight: 2.5kg
To view more jammers, including GPS jammer, cell phone jammer, wireless signal jammer, wfi jammer, bluetooth jammer, etc., please come to skybuying.com.
