kcomstock1 Posted March 4, 2014 Posted March 4, 2014 Have a 2006 GX470, is a great car, have only ever done regular maintenance other than the rear level sensor's failed 4 yrs ago. Recently one of the tire pressure sensor's went into alarm, which is false, was told by a local mechanic that all the sensor's in the car will start to fail due to end of battery life in the sensor's. Is this true or only for the tire pressure sensor's because they are wireless?? Kevin
imdav2u Posted March 5, 2014 Posted March 5, 2014 You might check the spare tire, if the tire is low, it will set off the alarm. This is the first time I have heard of a sensor battery going bad.
