Ossy1 Posted November 4, 2013 Share Posted November 4, 2013 My 1998 Lexus LS 400 Transmission Pan gasket leaks oil. I have changed it 4 times within the past month and still leaks oil. I don't know what to do. Quote Link to comment Share on other sites More sharing options...
landar Posted November 5, 2013 Share Posted November 5, 2013 Are you using cork, rubber or RTV gasket material? If you use the RTV or FIPG (Form In Place Gasket) material, that would probably be your best bet to stop a leak. 1 Quote Link to comment Share on other sites More sharing options...
Garo_mcc Posted November 6, 2013 Share Posted November 6, 2013 Even if you use a gasket try some Permatex high temp sealant as well, that away it's like double protection! 1 Quote Link to comment Share on other sites More sharing options...
landar Posted November 7, 2013 Share Posted November 7, 2013 I should mention that I had this same issue on my 98 LS400 and it was due to warping the pan while taking it off the transmission. Those pans are really stuck fast and when you pry to get it off, you will inevitably bend the pan on an edge, if ever so slightly. So, I cleaned the outside of the pan and let the car sit overnight. Next day, I pinned down the location of the leak and used a wide, flat blunt punch and hammer to peen the edge of the pan back into shape in the offending area. It worked. 1 Quote Link to comment Share on other sites More sharing options...
