Vsc /check Engine Light
river1
You will have to get an OBDII scanner hooked up to the test port (in the 'knee area' on drivers side) to read the trouble code(s). If you do not have such a tool already, you can drive to the nearest Autozone, Pep Boys, Advance Auto, etc and have them scan it for you. Or you could invest in a tool. They are relatively inexpensive (approx. $50-100).
Had Autozone check code p0051 said it is the bank2 oxygen sensor pass. side checked service records in 09 dealer replaced oxygen sensor pn 89465-50120 is this the same one?
