Front Lower Control Arm Bushing
fsuguy
Just thought I would post this for any newcomers with older LS 400s wanting to replace their suspension bushings. After much searching on this and other forums for the so-called "Strut Rod Bushings" I found out that there is no such thing, especially if you are trying to get OEM parts from the dealership. Instead look for the Lower control arm bushing (p/n 48654-50010 for the '92 LS400), There may be some incorrect references on this forum to a stabilizer bar as the SRB so make sure you know which part you are wanting to replace before ordering them. A good reference for parts with diagrams is the Toyodiy site - once you register with the site you will have access to the diagrams and part numbers, and you can check the part # I have listed above.
Hope this helps you all out - it did me!!!
