olduser Posted March 23, 2013 Share Posted March 23, 2013 Hi, I lost Headlights and Foglights ONLY. Taillights and running lights OK. Hi Beam do not work when used during daylight as a passing light. All interior ligts work as usual when lights turned on. However, the high beam indicator and headlights on dash indicator does not work when switch rotated on. High Beam indicator does not indicate when pulling back on the stalk. I dont beieve it is the rotating switch. as the high beam is a seperate switch. Interir fuses OK the relay works is there a seperate fuse just for the FRONT lower high and fog lights??? Thanks Quote Link to comment Share on other sites More sharing options...
fsuguy Posted April 19, 2013 Share Posted April 19, 2013 Hi, I may be wrong on this, since it has been a while, but you probably do have separate fuses in the fusebox under the hood - there are separate fuses for the right and left headlights; check those first. hope this helps Quote Link to comment Share on other sites More sharing options...
