Hi All
Re 2005 GS430 Power Windows. First time anything has gone wrong with this car!!
I'm in Australia and today is hot in Melbourne! I used the remote key fob to open all windows before getting into the car. All fine, But the drivers door window switches would only close the driver door. The other switches were dead. I can only open and close the other three windows by putting the key in the drivers door lock. (Or open all of them via the fob)
I searched both this and the Aussie forums for advice on resetting the windows / body computer. Eg half open the driver window, then raise and hold for 6 seconds. Then do same with sequentially the front passenger, then rears. No luck.
Another post said hold the driver window up for 12 seconds. That screwed up the calibration of the same window and didnt fix the others! (A full up and down via the key fixed the drivers window in this case)
Any ideas on the right approach welcomed! Is it a window reset? Or a full body computer reset?
Cheers
One day later.......Hmmm I repeated the 'wind down half way, go up and hold 6 seconds. It worked this time....' Good!
