rgodwin Posted January 19, 2012 Share Posted January 19, 2012 I need to replace my battery terminal ends on my 94 LS400 and I was wondering if anyone knew the size of + & - cable that is used Quote Link to comment Share on other sites More sharing options...
SRK Posted January 19, 2012 Share Posted January 19, 2012 #4 gauge is usually the smallest found on cars. To my eye Lexus must use #2 or #1 gauge. #0 or #00 ( aught and double aught) are normally found on large diesels. Quote Link to comment Share on other sites More sharing options...
landar Posted January 19, 2012 Share Posted January 19, 2012 Take a look at this site -> http://custombattery...do_you_need.htm The nomenclature is #1/0 = single zero("aught" or "ought"), 2/0 = double zero, etc...the lower the number or more zeros, the bigger the diameter. There is also a link to wire gauge size at the bottom of the page. You can measure your existing cable and match it up if you want to buy exact sized clamps. Quote Link to comment Share on other sites More sharing options...
