Help Me Diagnose Missing Problem
wallyman424
Hey guys, just picked up a 1999 ES300 that is having a strange issue.
When you accelerate from a stop at full throttle, the car feels very sluggish moving up the RPM range, and acts as though it is missing the entire way up. If you do the same acceleration at lets say 70-80% throttle its much faster and much smoother (like the car is supposed to be). Works just fine until the car hits like 55mph, then power just cuts out.
If I'm revving the car in park or neutral its the same story. Works well at part throttle, but full throttle it misses as its revving up.
To me this seems like 100% some kind of weird electrical issue. I'm having a tough time tracking it down though.
Things I have done:
1. At one point i had an VVTi OCV code for the rear bank, so I've replaced both OCV filters, and removed tested and replaced the RH OCV valve (they were both working to spec, but the rear one had a little more play in it).
2. No codes by OBDii scanning.
3. Cleaned MAF
4. Checked intake hoses for rips (there are none)
5. TPS seems to be working well based on OBDii diagnostics.
I'd appreciate any other ideas you guys have.
