Evap Codes, Canister, Emmision Help
JACEMAN99
Car: 1999 Lexus GS400
Miles: 188,000
Diagnostic Codes: P0440, P0441, & P0446
The car runs fine and these codes came up. I have a exaust smell and a swooshing sound (sound seems to come from behind dash). Sounds almost like fluid moving around. I am not sure if this issue is correlated with the codes.
A local Lexus dealer said I need a new canister for $800.00 + labor. I have not done any other test besides the Advance Auto diagnostic tool previously mentioned. I know the labor is reasonable due to the complex location of the canister.
I want to avoid a new canister if possible. I know the P0440 is general EVAP Emission Control System Malfunction. P0441 is EVAP Emission Control System Purge Flow. P0446 Emission Control System Vent Circuit Malfunction. Other than that I am clueless. I did get a brand new gas cap but the light never went off.
What other test can I do to isolate the issue?
Do I need a smoke test to check for leaks or breaks? Where do I Get one from?
Do I need to clean some type of filter or valve?
can I just replace hoses or valves: which ones and where can I buy these from?
Also does anyone know a way to get cheaper canister for this car? Part number:77740-30311
Thanks for your help and for reading!!
-JACEMAN99
