trussard Posted September 24, 2011 Share Posted September 24, 2011 Hi there, I just got her a new set of coilovers along with set of 19's. As the bad inward camber after getting the new coilovers, just went to a local shop trying to do a 4 wheels alignment, but I was told that I can only adjust the toe but not camber on our cars. That mean it will not doing any good even after the alignement. Can someone share his experience and let me know if there's a way to correct the camber? Thanks very much guys!! Quote Link to comment Share on other sites More sharing options...
cmartin248 Posted September 24, 2011 Share Posted September 24, 2011 You need to change alignment shops. Both the toe and camber are adjustable. With that said, even adjusting the rear camber to maximum, it will not go to zero. I actually modified my rear arms to allow "O" camber and I am now getting 50k on my tires. This is not a simple fix but the only way that I have found to get normal tire wear. Do a search on tire wear and you can see mine and others posts on the subject. Quote Link to comment Share on other sites More sharing options...
