1994 Ls400 H Fuse Blowing
jimmymeboy
Hello,
My Cooling Fan H-Fuse blows after one use, any suggestions?
Do you access the Cooling Fan Relay and ECT Switch from the top or bottom of the vehicle.
Thank you for your help.
Mike
electric motor bearings starting to seize putting additional load on motor hence current rises. Maybe you can take motor apart clean and re-lube bearings. Otherwise its a new fan motor...
