1995 Es300 Won't Start P0335 P0340 Intermittent
Yrag99
Need help with 1995 ES300 that intermittently won’t start. OBD reader indicates Code P0335 (Crankshaft Position Sensor A Circuit). I disconnected battery and then re-connected after about 10 minutes. Car then started with no problem.
I have had a similar problem (won’t start) in the past with code P0340 (Camshaft Position Sensor Circuit Malfunction) – disconnected and reconnected battery and the car ran fine for months.
In both cases, the car would sputter and misfire occasionally before it wouldn't start at all.
Time for the shop, or any advice on how to find what the problem(s) are? Thanks.
