scdaddy Posted August 8, 2010 Posted August 8, 2010 Recently aquired 1995 SC 300, noted that passenger floor board/carpet was wet after running A/C in the heat. Anyone know how to unclog the drain lines, assume this is a simple fix.
HFD Posted August 8, 2010 Posted August 8, 2010 Can't wait to hear more responses on this one! I have a 07 ES350 and recently discovered puddling of water under ALL the floor mats. The rubber backed mats prevented me from noticing the problem for some time. It's starting to smell! The dealer thought it was a clogged AC line; taking the car in on Tuesday.
tanline Posted August 25, 2010 Posted August 25, 2010 Can't wait to hear more responses on this one! I have a 07 ES350 and recently discovered puddling of water under ALL the floor mats. The rubber backed mats prevented me from noticing the problem for some time. It's starting to smell! The dealer thought it was a clogged AC line; taking the car in on Tuesday. Did you get an answer? I have the same problem on my SC400 passenger floor side...
jkendall93 Posted August 30, 2010 Posted August 30, 2010 it leaks because the drain tube that normally goes to the engine compartment to drain the condensation, has been plugged or crimped....look below the abs module for a rubber tube coming from the firewall.
