sizbob Posted June 11, 2010 Share Posted June 11, 2010 How do I get at the connector on the passenger side aft of cat converter? code P0156? Quote Link to comment Share on other sites More sharing options...
AHJGTA Posted June 17, 2010 Share Posted June 17, 2010 How do I get at the connector on the passenger side aft of cat converter? code P0156? 1. You pull of the frame/step on the right of the passenger seat. Hold it at the top next to the bottom dash compartment and pull it off. 2. Take out the vent cover. It's located just about where the passenger's left knee would be. A flat screwdriver in the rear (smaller)side usually gets it out. 3. Take the passenger seat back as far as it will go. 4. Pull on the carpet and bend it back 5. You should see a flat black tube to take air from the blower to the vents at the back floor. Take out the 10 mm bolt holding it down then pull the tube out by moving it around. 6. There's a tube in front for venting the condensation from the airconditioner. Make sure it's tight. 7. The wire for the O2 sensor should come out of the floor and the connecter should be hooked on to the wall. 4 wires: 2 blacks, 1 white and and 1 blue. Quote Link to comment Share on other sites More sharing options...
sizbob Posted June 19, 2010 Author Share Posted June 19, 2010 How do I get at the connector on the passenger side aft of cat converter? code P0156? 1. You pull of the frame/step on the right of the passenger seat. Hold it at the top next to the bottom dash compartment and pull it off. 2. Take out the vent cover. It's located just about where the passenger's left knee would be. A flat screwdriver in the rear (smaller)side usually gets it out. 3. Take the passenger seat back as far as it will go. 4. Pull on the carpet and bend it back 5. You should see a flat black tube to take air from the blower to the vents at the back floor. Take out the 10 mm bolt holding it down then pull the tube out by moving it around. 6. There's a tube in front for venting the condensation from the airconditioner. Make sure it's tight. 7. The wire for the O2 sensor should come out of the floor and the connecter should be hooked on to the wall. 4 wires: 2 blacks, 1 white and and 1 blue. Quote Link to comment Share on other sites More sharing options...
