wuzzy1 Posted January 21, 2010 Share Posted January 21, 2010 Greetings friendly gang members: I recently changed my alternator and now the odometer is not working. Does the 3 prong plug that goes into the alternator affect the odometer? I broke off the plastic clip when I removed it, and when I replaced it I just pushed it in all the way (I like the sound of that)! What does that 3 prong plug do? Many thanks! wuzzy1 Quote Link to comment Share on other sites More sharing options...
landar Posted January 22, 2010 Share Posted January 22, 2010 Greetings friendly gang members:I recently changed my alternator and now the odometer is not working. Does the 3 prong plug that goes into the alternator affect the odometer? I broke off the plastic clip when I removed it, and when I replaced it I just pushed it in all the way (I like the sound of that)! What does that 3 prong plug do? Many thanks! wuzzy1 wuzzy..I would not think the alt has much to do with the odo not working, as long as the charging system is working properly(it is, isn't it?). The connector into the alt. provides the field coil current for regulation. You most likely bumped or disturbed another connection while working on the alt. Or it is pure coincidence and a sensor has failed. I am a bit perplexed as to why the odo would not work, yet the speedometer works? Please clarify. Also, what year do you own? Quote Link to comment Share on other sites More sharing options...
