Whats the IS300 stock TPS adjustment at?? what voltage should it say? between .65 -.7 voltage? someone was playing with it and left the 2 screw loose and it was moving itself around... the voltage is out of whack... whats the proper voltage for me to set it at?
thanks.
found it.. with key turned off, unplugged tps and unscrew 2 little bolts, turn it to when it says .60-.75 between there.. i set mine at .65and its awesome.. idles real smooth. great acceleration too..
  • 2 years later...
Did you make measurements directly on the unplaged tps?
Thanks for info - need to make adjustment on my tps that has been moved by someone ( is300 2002 VVTI .
