mg27 Posted September 16, 2009 Share Posted September 16, 2009 Guys I would appreciate your help, I replaced all the bulbs in the rear still center panel lights are out and the trunk lock now is also out. I checked all fuses ok! so what is wrong any suggestions will be appreciated. thank you!!! the car is fantastic! Mario Quote Link to comment Share on other sites More sharing options...
mg27 Posted September 16, 2009 Author Share Posted September 16, 2009 Guys I would appreciate your help, I replaced all the bulbs in the rear still center panel lights are out and the trunk lock now is also out. I checked all fuses ok! so what is wrong any suggestions will be appreciated.thank you!!! the car is fantastic! Mario Found the problem! :D Lexus got a little cheap so it made the harness to tight and the wiring are breaking inside it! Now I have to splice the harness. Thanks hopefully this helps someone else. Quote Link to comment Share on other sites More sharing options...
