Removal Of Rear Door Panal
tschu
Hello All,
I have a rear window that is off the track. I need help on how to remove the door panal?
Thanks for your ideas.
Tschu
It's generally like the front door panels.
you pop the door handle circular trim using a flat screwdriver, undo the screw there. there shoud be a tiny hidden popout in the hand hold (where you grab to open/close the door) under that is the other screw. on each flat front / back edge of the door there are plastic screw "hide" covers. pop them for the last screw. note the back screw covers are actually plastic screws also. a dual-use. those come out all in one piece.
once all the screw parts are out, a firm grip at the BOTTOM of the door trim, pull straight out 2-3 inches with a decent ammount of force. once all the bottom is unsnapped the entire panel slides UP towards the glass window. its hard to describe but its held at the glass by a V shaped metal full length clip. thats why you do the bottom trim first and slide it up. or else some broken fingers are in your very near future trying to get it off from the top ;)
enjoy ! its a lot easier* than it sounds describing it in all honesty. total 5min job to rip the panel off. ^^
