ice06cold Posted June 15, 2009 Share Posted June 15, 2009 hELLO, I NEED SOME INFO FOR GUYS WHO HAS 22' ON THEIR GS. WHAT TIRE SIZE WOULD YOU RECOMMEND? A 245/30/22 OR 235/30/22? DID YOU HAVE TO CUT THE PLASTIC INNER WHEELWELL SO IT WOULD RUB IN THE FRONT? DID YOU PUT YOUR FACTORY SENSERS IN THE AFTERMARKET RIMS? I DONT KNO HOW TRUE IT IS BUT I WAS TOLD THAT IF I DIDNT PUT THE FACTORY SENSERS IN THE AFTERMARKET RIMS THAT IT WOULD MESS THE COMPUTER SUSPENION SYSTEM UP! THANKS FOR ANY INFO Quote Link to comment Share on other sites More sharing options...
Solidjr Posted June 25, 2010 Share Posted June 25, 2010 hELLO, I NEED SOME INFO FOR GUYS WHO HAS 22' ON THEIR GS. WHAT TIRE SIZE WOULD YOU RECOMMEND? A 245/30/22 OR 235/30/22? DID YOU HAVE TO CUT THE PLASTIC INNER WHEELWELL SO IT WOULD RUB IN THE FRONT? DID YOU PUT YOUR FACTORY SENSERS IN THE AFTERMARKET RIMS? I DONT KNO HOW TRUE IT IS BUT I WAS TOLD THAT IF I DIDNT PUT THE FACTORY SENSERS IN THE AFTERMARKET RIMS THAT IT WOULD MESS THE COMPUTER SUSPENION SYSTEM UP! THANKS FOR ANY INFO I have 235/20/22's for mine. They rub a little when making sharp turns but it only rubs the plastic in the rim well. Quote Link to comment Share on other sites More sharing options...
