1997 Es 300 Headlight Issue
Both of my low beam headlights went out at the same time. High Beams still work as do the fog lights. Could this be a fuse issue or a relay issue rather than both bulbs buring out at the same time? Is this a simple fix? Can I do it myself or do I need to take to a repair shop?
Thanks
Thanks
I had the same thing happen to me on a Toyota many years ago. I thought for sure it was a fuse or a bad wire. After trouble shooting I ended up getting ONE head lamp and tried it on both sides. Resolution: Had to replace BOTH low beams... just so happen that they both went out at the same time.
Thanks
Headlight control relay is probably bad.
