92LexusLS400 Posted April 23, 2009 Share Posted April 23, 2009 Hi im new to this fourm.. but yeah im trying to find out how to remove or reroute my idle control valve from the intake ..im having the ps fluid leak and the white smoke also...can anyone help me on this one? steps and pics would help alot thanks Quote Link to comment Share on other sites More sharing options...
92LexusLS400 Posted April 24, 2009 Author Share Posted April 24, 2009 i was told the idle control valve is bad thats why im leaking fluid and blowing out white smoke at startup .. Quote Link to comment Share on other sites More sharing options...
AzHotLS Posted April 24, 2009 Share Posted April 24, 2009 Item 11... http://www.lexls.com/tutorials/steering/pspumpremoval.html Quote Link to comment Share on other sites More sharing options...
92LexusLS400 Posted April 27, 2009 Author Share Posted April 27, 2009 Item 11...http://www.lexls.com/tutorials/steering/pspumpremoval.html thanks Quote Link to comment Share on other sites More sharing options...
Pepboy Posted April 29, 2009 Share Posted April 29, 2009 Hi im new to this fourm.. but yeah im trying to find out how to remove or reroute my idle control valve from the intake ..im having the ps fluid leak and the white smoke also...can anyone help me on this one? steps and pics would help alot thanks I had the same problem. Bought a new valve for $95.00. In order to install it I removed the air filter enclosure so I could have space to grab the valve with with a vise. The plastic vessel will break doing this but then you will be able to use a fixed wrench to unthread the valve and install the new one. It is a liittle tigh space to work. Woul'nt recommend to plug the hoses cause your steering wheel will be hard to turn on idle. Quote Link to comment Share on other sites More sharing options...
