ingood2 Posted April 23, 2009 Share Posted April 23, 2009 I own a 2006 es 330. Three months agoe the dealer reset the red check airbag warnig light but now its back on again. How can I reset the red check airbag light myself. Quote Link to comment Share on other sites More sharing options...
homemechanic Posted April 23, 2009 Share Posted April 23, 2009 I own a 2006 es 330. Three months agoe the dealer reset the red check airbag warnig light but now its back on again. How can I reset the red check airbag light myself. resetting is probably not going to solve your problem. you need to have it scanned for error codes. there are scanners for airbag only. it's not the same scanner as the ODBII stuff. the dealer should scan for codes and fix the error, not reset the light. i am not very confident about such dealership. think of it as your check engine light, scan for codes and fix it. i suspect your car is still under warranty. go and have them fix it ASAP. an airbag computer could run $1500 or so. i don't know why they are freaking expensive for a little computer box behind the audio system. Quote Link to comment Share on other sites More sharing options...
