Rear Problems
You can check it yourself... with the vehicle parked and off, just reach up an push/pull on the rear sway bar. If you can get noticeable movement, then that is a good indicator that's your problem. If it is, the bushing are like $15 for the set (of two), and they are super easy to replace. Just unbolt, remove/replace, and rebolt. I wrote a quick little DIY with pictures on here... I'm sure you can find it with the search function on this board.
