Fog Lights
66strat
i have a 1998 es 300 how do you replace fog light bulb
you can either go under the car and remove 3 size 10mm bolts and pull back the splash guard underneath the fogs and reach the bulbs from there, or you can go from the top and remove the sidemarker by removing one phillips head screw under the radiator cover like this...
if u need more info, LMK.
Thanks i'll give it a try..........
