94 Ls400 Noise From Drivers Rear Wheel
nikk777
The car makes a roaring noise from the driver side rear wheel area. Strange that it stops when you turn left. Thought it might be the emergency brake so I adjusted it all the way in but still getting the noise. Would this be a wheel bearing? How hard are they to change? I've done most everything else so should be able to handle it with some instruction. Thanks in advance for any help.
