eli2k Posted December 5, 2008 Share Posted December 5, 2008 Three questions - the first is if I park my car at night, then in the next day I want to start it, it is sort of harder to start up. If I leave the car for 30min and come back, the ignition is really fast, but in the other situation, it takes more 'time' that I have to turn the ignition before the car starts. Ideally it's maybe 500ms, but then the one that takes more time is maybe 2-3sec. Is this because the battery is going bad? I think one of the terminals is sort of collecting that crusty stuff, not sure if it is corrosion. I don't want to touch it in case it electrocutes me, so I'm not sure. Second question - if I leave my car parked overnight, the next day, once the car starts up, I wait maybe a minute, and get into Reverse and go back out, and then shift into Drive. When I shift into Drive, the car makes this loud jerk, which doesn't sound good. If I leave the car to warm up around 3-4min, however, then the problem goes away. I checked the transmission oil (I don't know if this has to do with the shifting), and it's fine, the other fluids are fine, too. I wanted to ask what was causing this, what I should check. Last question is, my uncle drove this car before, and usually when he stops at a long red light, he likes to shift the car into Neutral and told me it is fine. A friend told me if I leave the car in neutral it'll make something loose in the car. I assum Neutral makes the car work less. Does anyone do this when they reach a long stop? Is it bad for your car? Thanks! - Eli Quote Link to comment Share on other sites More sharing options...
kingjack133 Posted December 5, 2008 Share Posted December 5, 2008 1. clean the battery terminals with baking soda/water/and wirebrush..... see what happens 2. have a transmission service done...see what happens 3. putting the car in neutral or park should not hurt or looswen anything Quote Link to comment Share on other sites More sharing options...
eli2k Posted December 5, 2008 Author Share Posted December 5, 2008 1. clean the battery terminals with baking soda/water/and wirebrush..... see what happens2. have a transmission service done...see what happens 3. putting the car in neutral or park should not hurt or looswen anything Do I have to disconnect the battery first? Or I can just clean it with everything connected? Quote Link to comment Share on other sites More sharing options...
kingjack133 Posted December 5, 2008 Share Posted December 5, 2008 1 turn everything OFF 2 remove clamps 3 clean posts/clean clamps 4 apply treated felt post washers and vasolene...prevents corrosion 5 do all this in a timely manner. if you take to long the airbags are disarmed and must be reset by a dealer. i don t know what that time factor is. Quote Link to comment Share on other sites More sharing options...
