1994 Es 300
What type of leakage do you have? Oil, coolant...? It's real common on the older ES's to have the rear valve cover and cam seal leak oil. The oil will eventually drip down onto the exhaust downpipe and cause severe smoking and a burning smell. This is most noticeable while stopped at a stop light for a couple minutes. However, there is no way to even lead you in the right direction without more information.
