stevees Posted October 15, 2008 Share Posted October 15, 2008 The right front turn bulb needs replacement, The flasher cycles very fast. How do you get to the bulb? It is not obvious. Quote Link to comment Share on other sites More sharing options...
Lexucan Posted October 16, 2008 Share Posted October 16, 2008 Each headlight assembly is attached by three bolts. If you lift the hood and look around the headlight assembly housing you'll see them going through plastic tabs on the housing. Once these bolts are removed, the whole headlight assembly can be pulled forward so that you can access the turn signal bulb. Once the bulb is changed, push the assembly back into position and reinsert and tighten the bolts. Quote Link to comment Share on other sites More sharing options...
