peterab Posted October 6, 2008 Share Posted October 6, 2008 Has anyone had to replace a brake light in their sc430? If so, could you please explain how one can get to it for replaement. Need directions on how to replace tail light bulb!! Quote Link to comment Share on other sites More sharing options...
janiesue Posted December 7, 2008 Share Posted December 7, 2008 Has anyone had to replace a brake light in their sc430? If so, could you please explain how one can get to it for replaement. Need directions on how to replace tail light bulb!! Light bulb changed. I removed a philips head screw under a plastic cover on the lower edge of the light housing. Slid the light assembly off the hook at the top and slide assembly down, then access the socket and replac the bulb. Slid the light assembly back on the hook, replaced the scew and snapped on the plastic cap covering the screw Quote Link to comment Share on other sites More sharing options...
ldblair2000 Posted July 23, 2010 Share Posted July 23, 2010 Has anyone had to replace a brake light in their sc430? If so, could you please explain how one can get to it for replaement. Need directions on how to replace tail light bulb!! Light bulb changed. I removed a philips head screw under a plastic cover on the lower edge of the light housing. Slid the light assembly off the hook at the top and slide assembly down, then access the socket and replac the bulb. Slid the light assembly back on the hook, replaced the scew and snapped on the plastic cap covering the screw Perfect instructions. Thanks, it was very easy. Quote Link to comment Share on other sites More sharing options...
