Tail Light Bulb Replacement
peterab
  • 2 months later...
Pop off plastic cover, next to the light assembly, with a screw driver I removed a philips head screw under a plastic cover on the lower edge of the light housing. Slid the light assembly down and accessed the socket replaced the bulb. Slid the light assembly from the bottom back on to the clip, replaced the screw and snapped on the plastic cap covering the screw. Done!!
  • 3 months later...
Thanks for the tip - you are exactly correct. The light assemply was a bit difficult to pull down and away formt he body but it did finally let go.
