dave t Posted September 9, 2008 Share Posted September 9, 2008 '00 ES300. Since December I have been getting a Ck Eng light with a Trac light. The code used to show a "minor emmission control leak". This progressed to an "emission control leak". In both cases it would go two or three weeks before I had to reset it. Now it comes back on in a half hour or maybe 5 minutes. Time for me to get under the hood and check things out. I'm hoping some of you experts can save me some time by telling me the most likely culprits. I sort of assume a hose may have cracked or come off, I have the hose diagram. Is one of them more likely than the others to go bad? Any other common things to look for? Thanks in advance, Dave T Quote Link to comment Share on other sites More sharing options...
blk_on_blk Posted September 9, 2008 Share Posted September 9, 2008 I know there have been problems in the past with the charcoal canister on the EVAP system... it could be a pinched or clogged line... or a line that has fallen off. Do you know the code number specifically? Quote Link to comment Share on other sites More sharing options...
