On 2007 Lexus ES350 having problem adding names from phone book from Treo 700p (Sprint). Have phone paired but when adding names from phone book thru bluetooth, "transferring" appears but "failed" appears after a couple of minutes. Any suggestions?
Treo 700P Transfer Process:
Lexus:
From Telephone Menu:
Select: Settings
Select: Phonebook
Select: Transfer Data
Select: Group
Hold your Treo 700p and perform the next set of procedures
From the Telephone:
Select: Contacts
Touch the space to the left of the Category Drop-Down for additional Drop-Down selections
Select: Record
Select: Send Category
It will send whatever Category is selected in your Contacts listing. (Including All) This will allow you to set up the vehicle Groupings as the are on your phone.
Transfer should take 5 to 20 seconds depending on number of records transferred.
