tko001 Posted August 24, 2008 Posted August 24, 2008 On 2007 Lexus ES350 having problem adding names from phone book from Treo 700p (Sprint). Have phone paired but when adding names from phone book thru bluetooth, "transferring" appears but "failed" appears after a couple of minutes. Any suggestions?
amf1932 Posted August 25, 2008 Posted August 25, 2008 Treo 700P Transfer Process: Lexus: From Telephone Menu: Select: Settings Select: Phonebook Select: Transfer Data Select: Group Hold your Treo 700p and perform the next set of procedures From the Telephone: Select: Contacts Touch the space to the left of the Category Drop-Down for additional Drop-Down selections Select: Record Select: Send Category It will send whatever Category is selected in your Contacts listing. (Including All) This will allow you to set up the vehicle Groupings as the are on your phone. Transfer should take 5 to 20 seconds depending on number of records transferred.
