Does anyone have the OEM part numbers for front and rear brake rotors and pads for a 1999 RX300? thanks
Front Rotor 43512-48011
Rear Rotor (2wd) 42431-33030
Rear Rotor (4wd) 42431-33140
Front Pads 04465-48060
Rear Pads 04466-33050
Rotors are about $80 ea
Pads are about $45 per axle
Thanks so much for the numbers. Those must be Toyota prices. I called Lexus Parts Dept. to compare and their price quotes were much higher.
They are Lexus prices. Go to irontoad.com. Also prices at newlexusparts.com are usually about the same. I think you will find most of the parts can't be sourced from Toyota. Lexus and Toyota both use the same part numbering system. Sometimes you need to drop the "-" from the number for it to work in the Toyota system. But for the part number to be in the Toyota system the part must be used on a Toyota model. For example the RX rear pads are also used on the 4 cyl. Toyota Highlander so they show up in the Toyota system. The RX front pads are not used on any Toyota models so they show up as an invalid part #. In comparing the available parts there is no money to be saved here by using Toyota. Just buy using Lexus discounter.
